which is the best wires for a 3.8,MSD,taylor or acdelco,i can get a set of MSD's for around $60,which is the best?
Msd Vs Taylor Vs Acdelco
Re: Msd Vs Taylor Vs Acdelco
I lke MSD myself, I have had taylors, but for the past 8 years I've been running MSD 8.5 wires with boot protectors.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The MSDs are rated at about 50 ohms of resistance per foot, the taylors about 350 ohms, and the ac delco around 1000 ohms. Accell comes in anywhere from 25 to 500 ohms. The theory is that the lower the resistance the better the spark. But this also means your coils will reach peak voltage easier. This can aggravate coil misfire issues. I ran MSD for 2 years then went to accell extreme heat wires.
When I took my car to get it dyno'd last year (at a shop that builds and pretty much only works on race cars - mainly drag cars), the first thing the guy noticed when he opened the hood was the MSD wires I had installed. He said I should replace them as soon as I got the chance, that he had seen too many guys have issues with them. He also said something that I thought was weird, until I read the last post - that the MSD wires didn't have enough resistance. My thought was WTF? how can you have too little resistance? They did also have some trouble getting a good signal for the dyno through those wires, but I'm not entirely sure that was the wires. I still haven't gotten around to replacing them, but when I do I will probably go with Accell or Taylor.
FWIW, I run 8mm Accell wires on my 240SX race car, and have zero complaints about them.
On every dyno if they try to do it off the wires they will have problems , most of the time they can't get the TQ side to work. So they have to take it off the injector wire, for accurate reading.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i have msd super conductor wires on my 96rs and love them. I have taylors spiro pro's on my grand prix and their good too. I have accel 8.8 on my 69 and again not a bad wire. However, when i put on my roller rockers i had to go to taller valve covers so the wires barely fit. I'm going to replace them with universal set of msd 8.5 super conductors. I'd say msd is the best, but taylor and accel make good wires too. Can't go wrong with either make. If you want a comparable wire to msd and want taylors, check out their thundervolt 8.2 and 10.4 wires with 50 ohms resistence just like the msds.69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...23 hours ago
