Hey my fan won;t kick on till 245 and then shuts off at 210 what the hell is going on i know this is not normal one more thing will a bad thermostat cause this type of problem i need to know the mechanic who rebuil my engine says it's the radiator cloggged but even then it should still turn on at 210 right not 245
[ March 21, 2002: Message edited by: predator5100 ]</p>
My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
I have a stock 1994 3.4L and my fan operates in a similar fashion. Unless the A/C is on, the fans don't turn on until near the 3/4 mark on the temp guage(235F I believe). So, as far as I am aware, that is normal for our engines.
The thermo operation shouldn't affect the fan turn-on temp. In fact, when sitting still, i don't believe the thermo has much effect, but I could be wrong on that. Installing a manual fan switch will allow you to turn on the fan if sitting in traffic.
Does your temp get that high when driving, or only when sitting still? Regardless of outside temp, my car operates around 195-200F when moving. If sitting still it will slowly climb to 235, and the fan turns on, quickly dropping the temp back to ~200F. If you don't want a manual fan switch, you could just turn on the A/C in traffic to activate the fans.
Man, your cars operate hot. Change it out, especially if your in TX. My car operates around 170 (Houston) most of the time. It rarely rises over 220 and that includes running it at the track.
94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
Stagenb what do i change out it seems sometimes not to even work i just changed the sensor and nothing different happened. IS there a seperate relay or something my fan does turn on if i kick onthe defrost so i know the motor is good.
Hey what do i do now i changed the sensor for the coolant didn't do a thing how can i tell it my guage is off ever since the rebuild i've had nothing but problems, now i'm getting backfires and crap after an hour of driving
If your temp problem is when you are sitting still,
<blockquote>quote:</font><hr> Hey i'm trying to avoid any mods to the electrical well fan system my worry is overheating when i'm letting it warm up or cool down<hr></blockquote>
then I don't know how much good the thermo will do. The lack of airflow over the radiator when sitting still causes the temp to jump. You could remove the thermo (not advised!) and would still probably see the temp go up. That is why the fan switch is benefitial. On-demand airflow, even when sitting still.
[ March 25, 2002: Message edited by: Backfire ]</p>
If your car warms up fastr then it use to your thremo may be stuck closed or the coolant isnt flowing. You should fix it as fast as you can though, because oil starts to break down at about 255 degrees.
Well thats good to know however the fan is electrically controlled by two sensors and should kick on when the sensor reads 210 and it doesn;t and i've reaplced both sensors
