Parking Lights - FirebirdV6.com/CamaroV6.com Message Board
Parking Lights
  • Parking Lights
    My parking lights are melting or frying. Not sure, might be overheating. I just put in ultrabright white lights last week and one of them is fried already. The ultrabrights COULD possibly be the problem. But I already had a problem with the regular ones I had in before, that's when I put in the ultrabrights. Anyone experience this problem before? I also have the crystal clear parking lights, probably has something to do with it.
    Any suggestions?
    It's the big lights that are the blinkers, i think there the 3057s. not the little ones. when i took out the old one the plastic on the bottom of the light bulb was kind of melted.
    Not much you can do except replace the bulbs with factory wattage. I'd suggest some sort of way to release the heat out of the top of the housing, but then you're just asking for water problems.
    \'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
      Best bet is to disable your DRL's.
      Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
