I turned my car on and went for a drive just to find out that my ac isnt working right. do I need to have it recharged or ??
no cold A/C air!!!! help
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>Tags: None
my fan blows out air, but its not cold like is should be, i dont understand96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
the thing that used to be cold isnt cold anymore when it is running. how do you check for freon?? pressure switch???96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
Originally posted by Die Ford V8:
the thing that used to be cold isnt cold anymore when it is running. how do you check for freon?? pressure switch???1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
where?96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
usually I see places like presicion tune, shclep boys, or even sears advertising for free checkups or at least low cost one. Find out what they say & go fix it yourself ;)1978 Formula 461 in progress of being built :rock:
94 comero 3.4
this is the first time even really looking at the thing. can you give directions or point me somewhere that will show how to fix it96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
the guy at this chevron place tested and i have no pressure at all, he said he could find the problem for $38. they checked the pressure for free, but does anyone know where they could diagnose the problem for free. I guess they have to charge it to see where the leak is, but I dont have the $$$$...its $16 per pound of this stuff. wondering if I should save my money for the t-top kit and just leave the a/c on for now and later delete it. huh...sighhh96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
There are 2 pressure switches, one on the hi pressure line, one on the low pressure line. Try disconnecting the 2 pole switch and jump wire the connector. If the clutch engages you problably only need a recharge. Is there a leak somwhere you must find the leak with a charge and a leak detector.
You can also try connecting the ac clutch directly to 12 volts to see if it engages. Be careful with the connector....try finding a connector and make a jumper wire.
let me know how this proceeds----
Michael.
