what are the parts that make up most of the weight?
why are 3.8 camaros so heavy?
Re: why are 3.8 camaros so heavy?
i wouldn't say they are that heavy, sure they are heavy cars when you compare them to a Miata. but the engine is an iron block/heads that's where most of the weight comes from
i have seen somewhere a list of f-bod parts and their weights, i think from b franker...do a search for the weight of parts...might help.Team NoVa
I got rid of my floor mats and now it is alot lighter.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by cam98aro View Postbecause it is a car, and has a **** load of metal on it, which IIRC weighs a lot
well done mrhobbz...well done sir.
ava1219 are you looking to lower your race weight for track or just want clarification on why are cars weigh what they do? try removing your spare and jack, rear seats, any extra carpeting you can, or extra audio equipment if weight reduction is your main goal (a good start at least).
although our beloved f-bodies aren't the trimmest girls on the block, they could be worse like some of today's new 2-ton tire melters like the challenger SRT8. Even after Hennessey totally revamped the SRT8 and even force-fed it with a HPSH single turbo making over 600hp/tq, it still only has stock corvette c6 performance (400-436hp) because of all that weight it's having to launch. try having a guy with 200 less hp and half the money invested own you...that's a car in need of a diet.pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
gone in body, but not in spirit
Originally posted by cam98aro View Postframe?
floorboards?
engine?
im not sure if i understand this thread fully.
You can probably shed 300ish I'd imagine pulling the carpet, passenger seats and interior panels out.
on a side note...what is the GVWR in our cars mean? someone keeps telling me it is the cars weight...I can't see that as being possible...mine says 4100 lbs and I have the bases of all models...no t-tops, no power windows, no power door locks...no options really at all...I should have one of the lightest v6 camaros in stock form I think...
Originally posted by mrhobbz View PostWhat is it, 100lbs = 1/10th of a second? What are you trying to achieve here? You can probably shed 300ish I'd imagine pulling the carpet, passenger seats and interior panels out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostI think I have shed well over 300lbs , with a tub. K , tub. lower/upper A Arms, QA-1 front shocks& springs, Chromally rear control arms, panhard rod, front bumper support removed, tire/jack, back seats rermoved, lighter weight carpet put in, front seats replaced with lighter ones, fiberglass hood and rear spoiler, ALM. driveshaft, panhard upper peice removed, windsheild res. removed, cruise control, EGR, EVAP removed, also tunnel mount TQ arm removed everything on the tail of the tranny, RK sport headers, heat sheilds, all plastic under the front end removed, will be putting BAtt. in the rear and taking out stock coolant res. and putting in a ALM. 1QT. one. For the track have front Prostars that weigh 30lbs with tires. Also can drop my 35mm ST front sway bar for the track 35lbs and remove 25lb or so pass. seat and sub and amp about 50lbs from the rear. But will be adding about 100lbs in turbo stuff, so it all works out in the end.
haha, I like that...
Gross Vehicle Weight Rating. It's the maximum allowable weight when loaded, before the car becomes unsafe to operate
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
