low oil light - FirebirdV6.com/CamaroV6.com Message Board
low oil light
  • low oil light
    I have a problem again...
    I was checking the fluids this morning, then went to turn the car on and got the low oil light.
    But when I checked the oil the dipstick showed full. Oil change was about 300 miles ish ago.
    Also the car runs fine, no knocking/ticking just idle noise and gurgling from airbox.
    But if there is oil in the engine and the engine is running fine, then is it the oil pump? What are signs that the oil pump is out?
    Also can i drive around right now? Or not recommended?
    Thanks
    1998 Chevy Camaro 3.8
    1997 Chevy Camaro Z28 - SOLD 7-23-2011
    1996 Chevy Camaro Z28
    2001 Pontiac Firebird Formula
    Re: low oil light
    it's probably your oil level sensor. it is located on the side of the oil pan. what oil pressure is your gauge showing?
    2000 Camaro 3.8 v6 M5
    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
      Re: low oil light
      reading is right in the middle
        Re: low oil light
        ok so it is around 60psi? your oil pump is fine then. it's probably just your oil level sensor.
          Re: low oil light
          ok i can replace the sensor, thanks for your help! really appreciate it
            Re: low oil light
            The sensor is real easy to replace, I did mine about a month ago , because it was leaking through the sensor. I used some sealant around the new one because it was plastic and waited over night to let it dry. Worked out very good no more leaks. Good luck to ya.
              Re: low oil light
              Yeah it sounds pretty easy. where did you get the sensor from do you have part number for gmpartsdirect.com?
              thanks
                Re: low oil light
                I got mine from Checker Auto parts.
                  Re: low oil light
                  12603782
