ok i got a 2000 camaro with stock injectors but i want to get performance ones does anyone know were i can get new ones other than stock or maybe sumtype of swap i can do to the keg style injectors. the main reason i want the new injectors is cause i want to cam my car and sum piont turbo it
thx for anyhelp.
i would do cam first, then, when you are turbo-ing, do injectors. as long as they are clean and have good spray, the stock ones should do the job.
Team NoVa
i had stock injectors in my car when i got the dyno in my sig and was only @ like 80 some percent duty... i am in the process of installing a powerdyne right now @ 6lbs and i will continue to use stock injectors with a FMU until i put the 9# pulley on
