Inspection question - FirebirdV6.com/CamaroV6.com Message Board
Inspection question
  • Inspection question
    I'm planning on highly modifying my F-body. what will I have to worry about when inspect time comes around again? what exactly do they look for, and what would make me fail?
    Re: Inspection question
    well ith any kind of major exhaust, intake work itll throw codes but zzp makes a o2 sensor overide witch pretty much fixes that whole thing but i have a high flow cat and my left bank throws a code ever 160 miles or so. but thats plenty of time in between to pass emissions. 1 thing most people dot know tho is u have to atleast have ur light off for 100 miles to pass on newer cars other wise u get one of those stupid f'in 10 day temps but as for anything else no one will give u a prob but also take it to a local garage not a corperation cause a garage can bend the rules more
      basically, no SES and having a cat means you will pass emissions wise
      but really, every state is different, i would try to post this on a local car forum to your area, you will get better answers
        take a look at my car....i have no problems passing
        WAWA-A-HOLIC
          Find a backdoor place that will pass you without even looking at the car. That's what I did when I lived in an inspection state. Ask your friends or fellow board members of a place nearby that gives the hook ups.:)
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
