where did my antifreeze go? lol - FirebirdV6.com/CamaroV6.com Message Board
  • where did my antifreeze go? lol
    so a while back i popped open the radiatior while i was doing something else and was like hm.. i can't see anything so i added a half a bottle of water filled it up put the cap on didn;t think anything of it.. today.. battery died so while i was charging it i opened the cap hm couldn't see the water.. everytime i got it full the water vanished lol wtf.. i have no leaks anywhere! wtf where is it going!! no smoke from the exhaust oil looks good car runs like a champ. so wtf?
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: where did my antifreeze go? lol
    probably air got into the system, just keep refilling it and see if it stops going low
    i used over a bottle of antifreeze before mine stopped sucking it up
    also, im not sure where your location is, but i would NOT be using water to top it off especially if you are in ohio, go and buy some 50/50 mix and use that
      yah i thought about that after i did it.. i was like ****ing moron lol i am gonna get some mix in a little bit to top it off with
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        I was losing mine for a while and couldn't seemt o find out where it was going. had it pressure tested etc and still couldn't figure out where it was going. Now I'm going to be pulling the heads off, because I have a feeling it's burning through the exhaust, even though it's not smoking
        Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
          If you haven't change your coolant before you had this problem,then you definitely have a LEAK,it could be going in the overflow then unto the ground,I could be going in the cylinder/s but may not be that amount to cause the car to white smoke,it could also be going inside the car on the carpet from the Heater.
            did you test the cap?
            my friend had a mysterious coolant leak on his car and it turns out the cap could only hold like 5 lbs
              fwiw, I had similar problem last year...every couple of weeks adding a glass of coolant.
              After several months, it got worse...ended up being a bad intake manifold gasket.
                i had the same problem. bad plenum gasket, when i took it apart the area around where the coolant goes into the TB was all rusty and corroded. i ended up ruining a good set of heads because i forgot to check it...
                Team NoVa
                  4 days ago
