i was just wondering if going from dexcool to the green stuff will affect anything. i have a 96 bird and when the shop did the flush and fill they put in the green. should i be concerned about anything.
coolant issues
Nope you should thank them!New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
Yeah you have to get ALL of that dexcool crap out. They dont mix to well. but the green stuff is MUCH better! Like 94Teal said, you should thank them. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
By flushing the whole cooling system, we mean everything [motor, radiator, expansion tank], not just draining the radiator. I've heard that mixing the two types is seriously bad for things.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
If not flushed properly there will be a lot of jello looking thing in your cooling system. Not good for car.Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
Green Glychol antifreeze is NOT better then Dex-cool. It's a change that was needed. The low silicit formula in dex-cool is whats needed to maintain a healthy system in newer vehicles. Most of this reason is due to the different materails that the radiators and engines are made from. We have a lot more aluminum then we used to. The big thing that causes most problems with dex cool is the water used with it. you MUST USE DISTILLED WATER in any antifreeze mixture but is especialy important with dexcool. Yes mixing the 2 will cause a lot of issues.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
im on HBH's side. Chevrolet's people aren't stupid. the dex-cool is the one we are suppose to use for a reason and HBH made a good point. the only problem is the mechanics and owners that doesnt maintain the cooling sytem properly. if they didnt flush the entire system, i would thank them for ruining your stuff cause thats what is going to happen soon [img]smile.gif[/img]
My coolants got mixed by a mechanic and next thing I knew my whole system was clogged with a brownish red jello. My car overheated and I got it flushed. They must not have gotten it all out cuz the car has been overheatin ever since. It overheated twice yesterday and goin to the shop tomorrow. What a sad day. :(<a href=\"http://photobucket.com/albums/c368/rallysportchic97/\" target=\"_blank\">http://photobucket.com/albums/c368/rallysportchic97/</a>
exactly. Dex cool is in for a reason. Thats the precise reason that we should use it. When I got my car with 20K miles on it I flushed mine out and replced it with more dexcool and distilled water. It should have been fine but I just didn't want to chance that the owner before me didn;t use distilled water. if you stick to 50/50 distilled and dex-cool you will be set.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
ehh 50/50 peak is way better, no mixing stuff just poor it inwww.turbov6camaro.com
1997 3800 Series II Camaro
