Unlock both doors with 1 click - FirebirdV6.com/CamaroV6.com Message Board
  • Unlock both doors with 1 click
    OK, so I would like to re-program my car (2000 Camaro) to unlock BOTH doors with only 1 click from the keyless remote. It sounds minor, but I find it very annoying. I also have a 1999 Silverado I'd like to change also.
    If anyone knows how to do this it would be greatly appreciated. I spent over an hour searching this site and could swear I had found a skickey for this a long time ago that included many other re-program instructions.
    Thanks
    Russ
    Re: Unlock both doors with 1 click
    yea this would be great infromation if it is possible i have done it on my dodge but i have never been able to find out how to do it on a camaro it gets really annoying
      I've done the mod to my car, I found it annoying to have to click twice. I'll try to find the exact write up I used to get the wire colors and such. It's called a progressive unlock delete if that helps at all.
      EDIT: give this a look and see if it helps
        the auto window mod would be sweet.... hot summer day, just push the button and the windows roll down...
        MISC: 01 parts. Some interior, T top kit, seats etc.
        http://forum.camarov6.com/showthread.php?t=95347
          Yeah my dad's Accord does that stock, it has progressive locks and if you hold it down on the second press the windows roll down until you let it go. I've thought a couple times about doing it to my car, especially because it would make getting both the tops off a little faster. The wiring couldn't be that complicated, maybe I'll start looking in to it again.
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
