intake manifold/spray foam write up? - FirebirdV6.com/CamaroV6.com Message Board
  • intake manifold/spray foam write up?
    anyone know where thats at?? i can't seem to find it.. its where the guy used spray foam under his intake manifold..
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: intake manifold/spray foam write up?
    seafoam or regular foam?:D
      no spray foam like the insulation some guy made a write up and posted it he put it under his lower intake manifold
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        like inside of the engine?
        im confused
        was this on a 3.8/3.4 or a different engine?
          Are you talking about the molded upper intake WickedX6 did with his 3.8 where he cut the top and made like seperate runners for each intake port ?
            there is a gap between your intake manifold and your engine... this guy used foam insulation to fill that void so the intake wouldn't get as hot and therefor allow cooler air into the mixture.. i will do some more digging and try to find it..
            2001 Camaro 3.8 A4
            1991 3000GT VR4
              i give up i have looked though a few hundered threads.. it might have been on the other sight.. i remember seeing it around late6 early 07 i thought damn it!
              2001 Camaro 3.8 A4
              1991 3000GT VR4
                lies.
                  I would think the oil would degrade the foam... not so good for the motor..
                  MISC: 01 parts. Some interior, T top kit, seats etc.
                  http://forum.camarov6.com/showthread.php?t=95347
                    well it would have no way into the motor it just sits on top of it sandwiched between it and the lower manifold.. they make a version of the foam that is latex i think the oil would have a harder time breaking that down.. i am not gonna do it i was just wanting to find the write up so i could maybe email the guy and ask him some stuff..
                    2001 Camaro 3.8 A4
                    1991 3000GT VR4
                      so he is using it as a gasket?
                      im still confused about that you are talking about here
                        ever had your manifold off? if not i can't help you..
                        yes you use a gasket..
                        there is a gap between your BLOCK and your LOWER MANIFOLD that gap was filled with insualtion foam to keep the heat from the BLOCK to soak into the LOWER MANIFOLD. it goes on the upperside of the BLOCK between the HEADS and the under side of the LOWER MANIFOLD
                        2001 Camaro 3.8 A4
                        1991 3000GT VR4
                          oh thats real strange. i wouldnt reccommend putting foam down there.
                            why.... the engine won't get hot enough to have an effect on it.. i am not saying i am going to do it i was just wanting to talk to the guy that did it..
                            2001 Camaro 3.8 A4
                            1991 3000GT VR4
