anyone know where thats at?? i can't seem to find it.. its where the guy used spray foam under his intake manifold..
intake manifold/spray foam write up?
Re: intake manifold/spray foam write up?
no spray foam like the insulation some guy made a write up and posted it he put it under his lower intake manifold2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
Are you talking about the molded upper intake WickedX6 did with his 3.8 where he cut the top and made like seperate runners for each intake port ?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
there is a gap between your intake manifold and your engine... this guy used foam insulation to fill that void so the intake wouldn't get as hot and therefor allow cooler air into the mixture.. i will do some more digging and try to find it..2001 Camaro 3.8 A4
1991 3000GT VR4
i give up i have looked though a few hundered threads.. it might have been on the other sight.. i remember seeing it around late6 early 07 i thought damn it!2001 Camaro 3.8 A4
1991 3000GT VR4
I would think the oil would degrade the foam... not so good for the motor..MISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
well it would have no way into the motor it just sits on top of it sandwiched between it and the lower manifold.. they make a version of the foam that is latex i think the oil would have a harder time breaking that down.. i am not gonna do it i was just wanting to find the write up so i could maybe email the guy and ask him some stuff..2001 Camaro 3.8 A4
1991 3000GT VR4
Originally posted by vr4gasm View Postwell it would have no way into the motor it just sits on top of it sandwiched between it and the lower manifold.. they make a version of the foam that is latex i think the oil would have a harder time breaking that down.. i am not gonna do it i was just wanting to find the write up so i could maybe email the guy and ask him some stuff..
im still confused about that you are talking about here
ever had your manifold off? if not i can't help you..
yes you use a gasket..
there is a gap between your BLOCK and your LOWER MANIFOLD that gap was filled with insualtion foam to keep the heat from the BLOCK to soak into the LOWER MANIFOLD. it goes on the upperside of the BLOCK between the HEADS and the under side of the LOWER MANIFOLD2001 Camaro 3.8 A4
1991 3000GT VR4
why.... the engine won't get hot enough to have an effect on it.. i am not saying i am going to do it i was just wanting to talk to the guy that did it..2001 Camaro 3.8 A4
1991 3000GT VR4
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...13 hours ago
