Stalling Problem - FirebirdV6.com/CamaroV6.com Message Board
Stalling Problem
  • Stalling Problem
    my 97 maro has a sheitload of problems. the most noticeable is the stalling and this happens from time to time when stopped at red lights. the idle is rough though it hovers around 900 rpms. the car will just die and sometimes it takes 5-10 ten tries to get it running again.
    also, when i drive over long periods of time and then park the car for 10-20 minutes, when i try to start the car it wont start, only crank. this also takes 5-10 turns of the key to get it to start.
    when it starts in both cases, its a very weak start. the car doesnt jolt from side to side like it used to.
    ideas? questions? i need to fix this ASAP so any help would be GREATLY appreciated.
    2001 Pontiac Firebird<br /><br />Flowmaster American Thunder Cat-back - Yes, that\'s it... for now.<br /><br /> <a href=\"http://www.cardomain.com/ride/2273466\" target=\"_blank\">http://www.cardomain.com/ride/2273466</a>
    battery? alternator? is there any related problem when ur driving or is it just at start up and idle?
    '99 Camaro Y87 M5 T-tops
    Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
    Car Domain
      Do general check.Check fluids,Check ignition, spark plugs, replace fuel filter. Error codes?
        IAC?
        1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
