Ok it started out a few days ago my car started to not start on the first try it would try but it acted like there wasn't enough juice to get it started. So I took my battery to get it checked. It came back A OK so I put it back in and it started right up. I left my car parked over night went out to start it the next day wouldn't start. Moved on to the alternator it is fine also. It starts fine if you put a jump on it. My security light is on and so is the service engine soon also when you turn the key on like your trying to start it the check gauges light is on. All the gauges look normal but my battery one is low and kinda surges when you turn the key. I was thinking a short somewhere? If anyone else has any other thoughts please let me know. If you think it's a short to please let me know where you would start. Thank you Chris.
Starting Issue!!!
Re: Starting Issue!!!
those lights should be on when your key is on, thats completely normal
but when you do get it started, they turn off, correct?
try cleaning the terminals on the battery and the battery cables, they may be dirty and not giving you a god enough connection
No the security one stays on and so does the service one.... they have both been on for a while. I checked the battery connection the other day and it was a little bad but i cleaned up and the problem still came up. I just jumped started my car I am letting it run for a while and I am going to shut it off and see if it start again under its own power.
Originally posted by Baseballchris05 View PostNo the security one stays on and so does the service one.... they have both been on for a while. I checked the battery connection the other day and it was a little bad but i cleaned up and the problem still came up. I just jumped started my car I am letting it run for a while and I am going to shut it off and see if it start again under its own power.
The cost for my repair by the way was about $350.
I know this probably sounds funny but if I have a bad headlight that wouldn't cause my problem would it? It's been out for a couple days now every time I replace it the other one burns out a few weeks later. I'm not sure if it is a coincidence or if it's a short somewhere.
Originally posted by Baseballchris05 View PostI know this probably sounds funny but if I have a bad headlight that wouldn't cause my problem would it? It's been out for a couple days now every time I replace it the other one burns out a few weeks later. I'm not sure if it is a coincidence or if it's a short somewhere.
Originally posted by Baseballchris05 View PostSo after letting my car run for a little while I shut it off and let it sit for 10 min. went out started right up.
just because the tester said it was fine means nothing, those things are junk anyways.. how old is this battery?
even though its not 100% accurate, what does your volt gauge say when its running? a surging volt gauge like you described really sounds like the battery is too weak and can hardly turn the engine over
Originally posted by Baseballchris05 View PostOk so how is my key Running my battery low I don't get it I guess. Is it because there is a short there? The security light has been on for over a year I would say and the problem just popped up in the last week.
i still think new battery will fix your problem with the starting (it could be a bunch of things that is causing the bulb to keep burning out)
Originally posted by Baseballchris05 View PostAlso if it is the BCM wouldn't it not start all the time?
Originally posted by Baseballchris05 View PostAlso my radio does turn it self off or anything like that..... I have manual windows so I can't check that.... I am going to look a little more and then try to rip into it.....
im not saying your problem is that something is using it excessively.. i think you just have a bad battery.
i would replace it, and go from there.. how old is the battery in there now? it might need to be changed anyways
the fact that the car starts whn you get a jump means the battery is dead.. whether it is going dead because it is bad, or because something is drawing a current off of it, i have no idea, and you are gonna need to get a voltmeter
