Hey guys i was wondering if the oil pan would drop right out or is the crossmember gonna be in the way?
oil pan removal for 3.8
Re: oil pan removal for 3.8
yeah you have to unbolt the engine mounts and lift the engine up a little bit. The oil pickup that goes into the oil pan gets stuck on the oil pan unless you can pull the pan pretty much strait down
i made a thread about this a while ago.. i still have to change mine, but as kristen said, it seems hard.. IIRC she said the first time she did it, it took her 8? hours
im hoping it will be a bit easier for just a gasket change, i might be able to work my way around the pickup
daaaaaammn 8 hours. I installed a lift and welding up some exhaust in less time than that. Im sure she was farting around too. I can remove the pan and install a new gasket in less than an hour. hahaha I also have a shop with all air tools and heavy machinery and best of all a pit.
Originally posted by chevy3504me View Postdaaaaaammn 8 hours. I installed a lift and welding up some exhaust in less time than that. Im sure she was farting around too. I can remove the pan and install a new gasket in less than an hour. hahaha I also have a shop with all air tools and heavy machinery and best of all a pit.
[IMG]http://i53.photobucket.com/albums/g53/ahhwataday/truckweld.jpg[IMG]
[IMG]http://i53.photobucket.com/albums/g53/ahhwataday/trucklift.jpg[IMG]
a lot easier with a lift though, which i dont have
I'd lift the engine, if thats what you're talking about going around. Get it high enough to remove the pan and clean the old gasket off extremely well or you will be doing it again. Like i say, just stay positive and be fortunate you are able to have the opportunity to have a camaro to work on haha. I know alot of negative guys that either spend more money then they should or they get pissed easily. Good luck to you
Originally posted by chevy3504me View PostI'd lift the engine, if thats what you're talking about going around. Get it high enough to remove the pan and clean the old gasket off extremely well or you will be doing it again. Like i say, just stay positive and be fortunate you are able to have the opportunity to have a camaro to work on haha. I know alot of negative guys that either spend more money then they should or they get pissed easily. Good luck to you
