Well it came on yesterday and i have no clue why. I checked my oil and it was alittle low, and i added a qt. and it stayed on. So i had my oil changed today, and it is still on. It only comes on when i start my car, and only stays on for like 2-3mins max. Any idea what is wrong?
Oil Change lite
This light is simply part of the monitoring and reminder system. It does not directly monitor the lubricating properties of the oil. The oil change light is programmed more or less as follows.
As I understand it, the oil is not tested as some think. What the monitor keeps tract of is miles and speed. In other words, a car that is driven in city stop and go traffic will need to have the oil changed more frequently than a car driven at normal highway speeds and under light load. What the monitor tries to balance is miles and engine load.
In any case, under "normal" driving circumstance the oil and filter should be changed somewhere between 3,000 and 3,500 miles unless the engine is operated under heavy load and then the oil and filter should be changed before 3,000 miles.
Some will argue that synthetics hold up for a much longer interval, even under heavy engine loads, than regular oils, but no one can seem to put a number on the difference between the two types of oil and prove it. The proof may be there, but I have not been able to find it.
That is the way it was explained to me by a GM tech.
Look at your owners manual on how to reset the oil change light. On my 2K1 Camaro, you simply turn the ignition key to the run position , don't start the engine, and press and hold the tripometer stem until the light oil change light starts blinking then release the stem, turn off the ignition. The oil change light is reset. I suspect that it can be reset the same way on a Firebird, but I am not certain about that.2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
As I understand it, your computer actually counts engine revolutions as reported by your crankshaft position sensor. At a particular number it will tell you to change your oil. Simply turn your key to the on accessory position and push the trip/odometer button until the change oil light flashes and goes out.180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
Works the same for 'Birds, supposed to hold down for 12 seconds or so. ... My dad has the 3800 II engine in his Buick LeSabre, and he says the display reads 40-60 percent of the oil life is left after 3K miles. ... I've never let mine exceed 4K miles, and the light's never come on.2002 Firebird <br />Mods: Whisper CAI and Lid, K&N, Edelbrock Cat-Back, Hurst Billet Plus Shifter w/Lou\'s Short Stick, BMR STB, 32mm front sway bar w/polygraphite bushings and end links, PHB polygraphite bushings, HPP3 tuned
I think that the "Change Oil" monitoring system is pretty forgiving. I hammer my car ('01 Camaro) pretty good and it comes on for me roughly every 7,000 miles or so (but I change my oil every 3,000 miles just to be safe).\'01 Camaro M5 1SA \"Lightweight\" hardtop, Bright Red, Ebony cloth, FRA, Whisper Lid, B&B cat-back, Torsen 3.73 LSD, HPPIII (93 octane setting)<p>\'00 Camaro SS M6 T-Top, all GM and most SLP opts., Bright Red, Ebony leather, 4.10s, SLP long tubes, Loudmouth, CNC Stage II H/C, etc.
Oon my 99 Grand Prix, to rest the oil light, put the key i the "on position" and slowly press the gas pedal to the floor 3 times in 5 seconds. might work for you too1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
