Hey its me again....Okay My windshield wipers are actin crazy first of all when they turn off they actually stay up! ( And the hoes don't like that! ) Not only that now the one I had on the right side doesn't move at all anymore.....Whats goin on!!!!!!!!?? Any Ideas...HELLPPPPPPPPP :-(
Wipers
Re: Wipers
try popping the cap on the arms, make sure the wipers are turned off, and bring to the rest spot. Then tighten down the nut on the arm. If that isn't it then you fried the wiper trans/motor or broke an arm
Re: Wipers
if the motor wasnt working right, it would stop when it decided not to work. as far as the wiper being loose.. they are spring loaded, pretty hard to just spin around. but you can check just by trying to turn the wiper with the motor off...
either or, I have a motor and a set of wipers I can give ya cheap.
ArcherMISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
Re: Wipers
Originally posted by Archer View Postif the motor wasnt working right, it would stop when it decided not to work. as far as the wiper being loose.. they are spring loaded, pretty hard to just spin around. but you can check just by trying to turn the wiper with the motor off...
Archer
How much are you letting them go for?....and will it all go onto a
94 body camaro?
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
