I have a 1998 3.8L Camaro. For the past week she's been starting up only when the day is right for some reason.
It was cranking but wasn't turning over. I took the battery to get checked and purchased a new one since a lot of the acid dripped out. So with the new battery the car started up just fine, but the next day didn't start at all. I cleaned the terminals then it started up all day. The next day failed to start again and since last Saturday (3/7) I cant get it to start anymore.
This is everything I checked and is in working order:
-Fuses
-Fuel filter
-Fuel pump (I hear the it "buzz" on when I turn the key)
-Starter
-Ignition Control Module
-All 3 coils
-Air filter
-I have gas
Im sadly running out of options.
Can you guys recommend anything else I should check? Thanx for the help and input! :o
-Fuses
-Fuel filter
-Starter
-All 3 coils
-Air filter
-I have gas
