I was having zero power to everything no lights anywhere , nothing , and then I remembered I was messing with the red power accessory little box I opened it up and it was full of dirt build up and dust from my paint job in Jan. so I cleaned it up and it started right up. I guess that must be a power to the PCM because I would lose all my radio stations and clock when it did this. From time to time I would just get a clicking noise coming from the passenger side and would have to turn the key back off and restart it and it would fire up. Just something new I learned from over 13 years of having it it is the first time I cleaned the box up. Before that I went through every fuse and relay I could find checking them. So if someone has a similar problem , this is what to check out. It also might connect to the BCM thinking about it.
Some info I found out
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Some info I found out
you are correct, it does connect to the bcm. If the bcm does noot receive a signal, it cannot send a signal to the ignition. On the other hand, it's kinda funny that the power accessory wire would contribute to 0 power. It should cut off the power windows, radio, and about 10 other things. I wouldn't think having build up on it woould cause the ligths not to work. Oh well, you learn something new every day!Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
^ I had total loss of power to everything, glad I found that problem.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
