wont start - FirebirdV6.com/CamaroV6.com Message Board
wont start
  • wont start
    my car wont start, i dont hear the fuel pump turning on when the car is in the "on" position, is this a bad fuel pump or filter or what? i tried searchin but cant find anything, thanks for anyones help
    *1997 Camaro v6 3.8*<br />President of NorCal Sinister Six
    anyone? at all?
      Not enough info here!Does it turn over (crank),& did you check the sometimes too obvious,ie battery,or did you put a spark tester on the plugs,assuming it does crank?
      geocor
        normally I'd say check the pink wire ( :rolleyes: [img]graemlins/slap.gif[/img] ) but is anything else happening w/the key in the "on" position. Might be the infamous VATS/PASSKEY wire breakage.
        edit: try a search on it. plenty of good info out there ;)
        2013 Ram 1500 Big Horn
        94 comero 3.4
          no everything else turns on, radio lights the works, it started up today and was running at idle rough, then i turned it off, then tried agian and nothin. when i turn to to the "on" position i dont hear the fuel pump turn on so im not sure whats wrong
