not sure about this,,will it work?? - FirebirdV6.com/CamaroV6.com Message Board
  • not sure about this,,will it work??
    11-24-2008, 07:17 AM #9
    whitefox
    Focus Addict
    FF Member#: 54401
    What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
    FF Reputation: 27
    Buy-Sell-Trade Rating: (0) My grandfather had told me once to use transmission fluid to flush the crankcase if there are indications that the oil is not cleaning all the crud out.
    The steps for this; drain the oil, change the filter. Put the recommended amount of trans fluid in the motor (if the oil capacity is 4.5 quarts, use 4.5 quarts of trans fluid. Start the engine and let idle for about thirty minutes. Drain the trans fluid, replace the filter. Fill engine with recommended amount of motor oil.
    This will usually clean the crankcase, another way is what viney266 says - use good oil and change it often (I would say about every 2,000 miles). Do this until the oil comes out clean, then fill with a good synthetic.
    __________________
    Carl - whitefox -
    Team Duratec # 164
    2008 Focus Ebony Clearcoat 2dr SES 5spd
    Re: not sure about this,,will it work??
    yes, it will work
    transmission fluid has more detergents than regular oil does
      Yea, let me know how that works, so I can get right on NOT DOING IT.
      *Matt
        suit yourself, but it works.....
        05' CTS-V
        00' Camaro - SOLD :(
          never said it didnt work, I said Im not going to try it...
          *Matt
            there is no reason to try it unless you have a severe engine problem
              agreed...or just high mileage....
              05' CTS-V
                I've always understood that it will destroy the bearings.
                  Sounds scary.
                  Let us know how it goes though.
