from MAP TO FPR can i use a soft vac line instead of the hard line that is on it? i snapped mine in half.. also anyone know the size so if i can use a soft one i can get one before i go work on the car tomorrow?
vac line question
Re: vac line question
i did the same thing when i did my manifold gaskets, you can get the hard stuff from o'reillys in like a roll of 3ft....as for the soft, cant help you.Team NoVa
I think the size is 3/8" or 1/4" ,I 'll have to look at it, will post later on , if I get a chance unless someone posts it sooner.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i would rather use soft.. but i am not sure if the suction is so much it will collapse the line.. there has to be a reason they used soild2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
I used a hard type rubber line, so it doesn't crack or rip easy. I'm aheaded over to get me car hand washed & waxed, so I'll take a look when I get back. I want to say it was 3/8" though, Because it made that plastic line running back there look really thin.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
