How did you guys that deleted your a/c go about capping your lines when you cut them? what did you use and how did you do it?...hopefully wednesday of this week I am going to take out the cannister and the coil at the front of the car...compressor is coming out in may...
capping the a/c lines
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: capping the a/c lines
System is completly drained (legally)...I have no intention of ever putting A/c back in...hasn't worked for over a year and a half...and I havent used it in 2 years...I just want to take everything out, but I still need my heat...I just dont want to cut these things and have problems later...
so how would you get those hoses out then?
yep...Im not doing anything until I have everything and know what im doing...I do have the shorter belt on right now already though so...all thats left is the weight reduction portion...
So I unscrew these lines from both sides...on side is the canister, the other side is by the firewall? What goes onto the pipes at the firewall?
I'm doing the same to mine. Going to see if I can find shipping caps to just keep general crud out of the evaporator core. Could I ask what size belt you used and how did you route it? Did you use the idler or skip it completely?
These are not from my car, but are pictures of how mine is routed...steddy you also have a pm
[ATTACH]2782[/ATTACH]
[ATTACH]2783[/ATTACH]
Originally posted by LETZRIDE View Postso its perfectly safe for the evap coil lines to remain open? what happens if crap gets in there? anything?...I might take the evap coil out in the future as well...I know you gotta take out the heater core to get to it though, and cut something in the firewall to get it out or something...
oil from what?
