i currently have a 98 firebird 3.8 5 speed manual with 99,000 miles and with no modification and my car is going through gas like nothing it literally takes about 3 days of normal driving to kill 3/4 of my tank is this normal and what can i do? ive tried gas additives like Lucas and all those and nothing still doing the same ?
My car is eating my gas tank is this normal!!!!????
Re: My car is eating my gas tank is this normal!!!!????
Drive so you don't have to use your brake pedal as much. Change both the o2 sensors BEFORE the cat if you haven't recently. Lighten the car up if you can. Don't use the AC. Normal maintenance other than that. I'm sure more people will chime in with other suggestions/ideas. Yeah, check your Fuel pressure.. Make sure no gas is leaking into your vacuum port on the FPR.
TEAM C6V6
Maybe some new plugs and wires if theyve never been changed... New airfilter. Like stated above the 02 sensors in the manifolds might be shotty. I try not to go above 2.5k rpms when DDing.
Did it start doing this all of a sudden? If it did, then there is probably a sensor problem, like one or both O2's went bad. If the ones in there are original, try changing them because it needs it anyway. They can get lazy over time. Not enough to throw a code, but still cause problems. I think bad O2's are the biggest cause of poor mileage, except for underinflated tires and lead feet.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
are you filling the tank all of the way up?
i can put 7 gallons in and it will say full, but the gauge goes down quickly.. lasts me less than a week, if i completely fill the tank up, it will still read full, but stay there for a week, then drop down to E after 2-3 days
after i hit the 3/4 mark i have about 100 miles before my tank is on E
and the last time it was tuned up was???
ok, i didnt see this up there anywhere, but if you are driving like 350 miles every three days, that will use up some gas...have you checked what milage you are actually getting?Team NoVa
Originally posted by flamingchicken View Postok, i didnt see this up there anywhere, but if you are driving like 350 miles every three days, that will use up some gas...have you checked what milage you are actually getting?
^xxxx208' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by PettrrHey all,
I know this is a Camaro forum first and foremost (mine's a ‘00 V6), but I figured I'd ask — does anyone here also mess around...17 hours ago -
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 week ago
