battery will not hold a charge - FirebirdV6.com/CamaroV6.com Message Board
  • battery will not hold a charge
    I have tried every thing ,new battery,alternator,i think there is a major draw somewhere,have any of you guys had this problem?
    Wiring? I'm not sure, how long does it take? Are you saying that your car loses power like you are reading on the dash, or are you saying that your car goes dead like no power at all?
    -235/4517 Chrome Mondera Solaris<br />-Hornet remote start-keyless entry<br />-Pioneer 8400/CD/MP3<br />-2 Audiobahn 10\'s in custom box<br />-Flowmaster exhaust-SLP CAI-*180<br /><br />Never underestimate the predictability of stupidity....Tony from \"Snatch\"
      My car gets a boost and it will run for a few days but then the power just draws out sitting there,so there is a major short. i dont want to, but a shop is where this is leading to. thanks for your reponse
        Have you tried using a test light between the neg cable and neg post on the bat? Just disconnect the negative cable clip a test light wire to the negative cable then touch the negative battery post with the probe if the light stays on something is staying on, so you would one by one pull a fuse from the fuse box to see if the light goes out, if say pull the accy fuse then its something on that circut draining the battery. I had a similiar issue for me it was my door lock relay.
        1990 Firebird 3.1 T-Tops<br />Flowmaster exhaust<br />Kenwood MP 825 Deck<br />4\" Rockfords w/ tweet in dash plate<br />3 Way 6x9 Rockords in rear sails<br />1970 Camaro 350
          Hey ,Thanks alot for the advice javelin i will try that.
            Javelin thats a good tip, and i've heard it and tried it on many cars but some cars that are equipped with a security system that contain the flashing LED in the dash will always draw current from the battery thus always failing that test.
            <a href=\"http://albums.photo.epson.com/j/AlbumIndex?u=4187730&a=31095602&f=\" target=\"_blank\"> 2000 Black Firebird Y87 </a> <br />K&N filter, Whisper Cold Air Intake, Cutout Exhaust;<br />3.42 Gears, LSD;<br />160* Powerstat, Removed Silencers, MAF screen removed;<br />Zex hyperformance Spark Plugs, MSD Superconductor Wires, Manual Fan<br />Switch<br />15.08@90.86 2.149 60ft
              bust out the multimeter
              ~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
                you could alawys unplug the brain if it has an alarm.
