i wired up the (+) and (-), i just dont know where to hook up the wire from the O2 sensor..... do i tap a wire under the hood or one under the car near the sensors themselves, and if thats the case, which one, b/c theres like 3 or 4 I hear?
thanks
1999 White Ford SVT Lightning.<br /><br />Hoping to dyno @ 450hp/550tq by the end of \'04.
You need to tap into one of the O2 sensor wires going into the PCM. You want the O2 sensor that is just before the cat. On the 3.4L I cant seem to find the right O2 sensor in the Chiltons. I found the left and right sensors that are on the manifolds. They are pins 21 and 22 respectively on "Connector B". They are purple and purple/white. These really are not what you want because the reading will jump around too much. Um.. I cant seem to find any other O2 sensor on the 3.4L, so you may have to use one of those.
Does anyone know more about the 3.4L O2 sensors?
~Brian
NEW 2002 Onyx Black SS Camaro<br />M6, leather, T-tops, Hurst shifter<p>sold: 1999 Pewter V6 A4 Camaro
On a 3.4, you only have a choice of manifold left or manifold right, so take your pick, but only one at a time please.
The stock O2 sensors are switching type sensors. You do realize that all you will see on an A/F gauge is rich or lean as the ECU flips and flops the mixture. You will not be able to see anything that could be considered a reliable A/F ratio.
If you wanted to do it right you could just buy an O2 sensor ( or just pull one off a 3.8L in the Junk Yard ) and mount it right after the Y-pipe. Just pull an O2 from the Y-pipe from under a newer F-body.
~Brian
