Lots O Problems - FirebirdV6.com/CamaroV6.com Message Board
Lots O Problems
  • Lots O Problems
    My car was over heating , and i drove it hot for a short time. I figured out that my water pump went out. Now when I drive I can see and smell coolant burning. I think i blew a head gaset. So I got a compression tester and put it in place of my spark plug and its reading 0 (Did I do the compression test wrong ?) , I researched and its supposed to be about 150 . And when I try to drive my car feels like it has no power. I put the car in drive and my transmission barely moves. I give the car gas to like 3000 rpm and the car inches . Is my tranny out now ? My car has 168,XXX miles Need info and help bad
    Re: Lots O Problems
    if you are getting 0, you are obviously doing the test wrong
    how exactly did you do the compression test?
      Re: Lots O Problems
      I took out the spark plug and put in the adapter , attached the hose that has the compresion gauge and started my car
        Re: Lots O Problems
        does the gauge still work?
        i would imagine starting the car with it in would break it
        you are suppose to take all of the spark plugs out, disable the ignition, open your throtle body all of the way, and crank the car for about 5 seconds
          Re: Lots O Problems
          yeah I am renting it from Vato Zone , so it should work
            Re: Lots O Problems
            how do I do that ?
              Re: Lots O Problems
              i would just pull the plugs/wires and make sure they cant arc anywhere
              then just jam something in the throttle body or stick something on the pedal if you have a 98 and below car
              my guess is that you may have broken the gauge starting the car up with it on
                Re: Lots O Problems
                hmmm but this a basic little thing . How could I have broken it?
                  Re: Lots O Problems
                  Also, you should disable your fuel pump. On mine (2000), I removed the relay for the fuel pump and I unplugged the icm connector. When you say you started your car with the gauge hooked up, you don't mean the car was actually running do you?
                  2000 Camaro 3.8 v6 M5
                  Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
                    Re: Lots O Problems
                    thats the way i took it, im betting if he didnt pull the fuse for the fuel pump and left the other plugs in, he just bought himself a new, broken compression gauge
                      Re: Lots O Problems
                      no it works haha man I feel dumb it wasn't plugged in all the way. My compression is at 90 :( blown head gasket
                        Re: Lots O Problems
                        did you test all cylinders?
                          Re: Lots O Problems
                          check oil quality? coolant levels?
                            Re: Lots O Problems
                            oil looks good not milky and coolant levels were good.
                              Re: Lots O Problems
                              well, then your gaskets are fine and not the cause of you overheating and performance loss. Do you still have the original cat on the car?
