3.8V6 Engine problem - FirebirdV6.com/CamaroV6.com Message Board
  • 3.8V6 Engine problem
    HI,
    question
    I just read GM recalls 1.4 million cars. for a problem with the 3.8V6
    i have a 2001 3.8V6 Camaro, the Camaro is not on the list.
    does the camaro don´t have this problem ?
    Patrick (Netherlands Europe)
    Re: 3.8V6 Engine problem
    Don't worry about it. You might be able to do that if you go in reverse up to a pretty high speed then hit the brakes. But I really doubt any of us will be doing that.
    TEAM C6V6
      hi,
      is the 3.8V6 Camaro engine so different ?
      the cars are on the list are all front wheel drives, or has this nothing to do with it ?
      Patrick
        i have a 01 v6 3.8 camaro. never had a problem *knock on wood*
        WAWA-A-HOLIC
          Sounds to me that it may be with the valve cover gaskets leaking, in which case, with transverse motors, may cause a problem with oil leaking directly onto the exhaust manifold, giving the chance of an engine fire. When I found mine, I thought there may be a possible problem to it, but just fixed it. No more faint oil burning smell. I also don't believe we have the spark plug wire channel, or at least on my '96, there's just the normal wire retainers.
            it looks like it is more for the FWD 3.8 engines
              If there was a problem, or a chance of a problem with the camaro, it would be on the list.
              *Matt
