Headlight motor stuck on - FirebirdV6.com/CamaroV6.com Message Board
  • Headlight motor stuck on
    My left headlight on my 99 goes down and the motor still runs and sounds like the gears stripping. They still go up and down, but it wont shut off. I had to pull the two 15A motor fuses with them up until I know what to do....can anyone help? Do I need a new motor? Thanks, jessica
    Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
    http://www.projecttransam.com/ go here and buy a brass motor gear off of this guy. It's jsut your nylon gear is stripped. All you need to do is buy a new one and install it. I have the same problem right now, but dont have the money for the part. It's a hard install and I think they have a video on it floating around somewhere. If you have problems with the install, just post on here and I'll go through it with you step by step or AIM me at:
    pierrebaker
    take care and good luck
    Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
      Do a search, there is a bunch of stuff on this.
      Oh wait, here you go.
      http://www.bfranker.badz28.com/headlightfix/#FreeGuide
      Free headlight fix mod. [img]tongue.gif[/img]
      ---Niño---<br /><i>95\' silver 5 spd</i>
      • Andy H
        Transmission removal help!!
        by Andy H
      • 2.8 Bird
        Abs inop
        by 2.8 Bird
      • fishin
        by fishin
