Keyless Entry on 99 F-bird - FirebirdV6.com/CamaroV6.com Message Board
  • Keyless Entry on 99 F-bird
    I have a problem i do not know if my car has keyless on or not because i got it from a wrecked car dealer do 99's come standard with so then should i just buy the remote?? PLease help!!
    !!No Worries!!<br /><br /> <a href=\"http://www.cardomain.com/memberpage/515424\" target=\"_blank\">http://www.cardomain.com/memberpage/515424</a>
    Check the RPO codes to see if your car is equipped. Looks like AU0 is keyless entry.
    http://tech.firebirdv6.com/generalspecs.html
    Matt
    1998 Mystic Teal Camaro M5
      Hey where are they located i cant find them on my drivers side door or in the glove box??
        PLEASE I NEED HELP!
          It should be on the drivers door. A little metal piece attached to the door will have a bunch of 3 letter codes on it. If you do have it you can buy a new remote off ebay and you can find the programming instructions on here somewhere.
            Like where though?
              should be on the drivers door like others are saying; my 02 is. If yours is gone then for some reason someone prob removed it. Do you have any stickers at all on the inside of your doors? Like even the VIN, production date, tire sizes, etc?
              2006 Tiburon
                aye, it's just a bunch of random codes.. should definitely be inside the door
                ~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
                  Yes i have all of those that u mentioned but not the random #'s from GM are they on a seperate one or are they with those!
                    of yoi have the sticker with a bunch of 3 digit codes, thats the option sticker
                    if you don't have that code, you don't have keyless entry (assuming that is the right code)
                    But simple solution, find a friend with a f-body and test program their remote on your car ;) I've got 4 remotes here and most of my friends with f-cars have a fewextras
                    Ryan
                    1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
