Low Oil Light - FirebirdV6.com/CamaroV6.com Message Board
Low Oil Light
  • Low Oil Light
    I own a 97 V6 M5 Camaro. I have owned the car for a few years now and it has served me well.
    Recently the low oil light lit up on my dash. I was almost due for an oil change so I took care of that. The next day the low oil light came on again, but my oil level was still full since I just did the oil change the day before. This appears to be an intermittent problem, as it doesn't always come on.
    Could somebody give me advice as to what could be causing this?
    Re: Low Oil Light
    dirty oil level sensor in the oil pan
      Re: Low Oil Light
      I'd say just buy a new one, it's fairly cheap (under $15 IIRC) and real easy to change out. Best to be done during an oil change I'd say. When I changed mine it was literally ~20 seconds added on to my oil change
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        Re: Low Oil Light
        Thanks for the info. I'm going to look into it for my next oil change.:banana:
          Re: Low Oil Light
          I don't think Jiffy Lube changes out oil level sensors, I could be wrong though.
            Re: Low Oil Light
            I try not to take my car to a garage whenever possible. So far the only time my Camaro has seen a garage was for alignments and inspections.
              Re: Low Oil Light
              I thought you had to reset these? Hold down for so many seconds, with key on engine off... Or am I thinking oil change light?
              98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
                Re: Low Oil Light
                yup, you're thinking of the change oil light, which IIRC was only on 99+ cars
