If some of you feel the need to delete your AC for whatever reason, the first cost effective idea you may have is to just wrap the serpentine belt around the Alternator. This however effects how much pressure the actual tensioner can put on the belt. Then the belt starts to wear in as they all do and loosen up. Well it's just too loose. The belt from the Alternator to the Power Steering pump starts to flap around like crazy. Mine even ate away at my ECT sensor clip.
I believe I stole this idea from someone who posted it awhile ago. I can't remember who exactly but thank you for the idea.
Keep as much or as little of the AC compressor bracket on as possible to just support the Idler pulley. I left my whole bracket on because I think I'll be reinstalling my AC. It just get's too damn hot in that car. Either way, you can replace the Idler pulley with a grooved one from autozone or wherever. Employees at autozone will resist initially saying that it's not a stock piece and they can't look up what you need. You can then kindly ask them to compare your idler pulley, which you've removed and have on hand, with a grooved idler pulley from a different vehicle. They usually don't like that idea, but they'll do it. Hah.
Anyways, here are the pics.
And there's just a tiny lip that needs to be ground down to allow clearance for the new routing.
Easy enough. And the tensioner can now effectively do it's job. No more floppy belt.
