to those who ported and polished their own throttle bodies...?
what were the results? was it worth the time to do?
im pretty good with a dremel, and have *** loads of bits for polishing and grinding but is this job doable with just a dremel? or do i need something more powerful?
also, if u can find some walkthroughs that would be awesome.
thanks
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
also can i re use the TB gasket? or is a new one necessary
Originally posted by Tyler: also can i re use the TB gasket? or is a new one necessary
Why would you want to reuse it? They cost maybe 5 bucks, and you wouldn't have to worry about it leaking. Hell, you could even use just RTV and not have to buy one if you wanted.
i've played with porting it, never actually finished...and to be honest there hasn't been a whole lot of difference...but if you polish it up it might help.
Why not re-use the TB Gasket? Do tell, do tell.
And Jonny's guide is very nice and complete, and when he ran on the dyno with the ported TB he had some big numbers. Of course, now he's at 14.0's ...
-Rob
when i removed the front bar that holds the blade on the TB i polished the whole TB with rubbing compund .. looked like a freakin mirrior when i was done (watched a ball game and polished it to pass the time)
i reused the gasket.. ive had the TB off a few times and have allways used the stock gasket, no problems here
