hydrogen generator - FirebirdV6.com/CamaroV6.com Message Board
hydrogen generator
  • #31
    Re: hydrogen generator
    I use methane. Got the intake ducted to right below the drivers seat. I've found Taco-Bell to be the cheapest fuel.
    First law of thermodynamics will get ya every time. I wouldn't waste your time. I'm with ne0hisda0ne and the rest of the nay-sayers.
    • #32
      Yeah its the same episode guys...
      Anyone that understands what Im saying (about the law), think of a way to use the wasted energy? Thats what we should be focusing on. The energies right there, lets harness it. I cant think of anything :(
      98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
      • #33
        i never really thought about it before but im thinking about it a lot now i understand it takes engergy to make it but i think mabey you end up with more usable energy than you had before especially with the chemicl yes you have to buy it but for only a few dollars compared to a few hundred for gasoline
        • #34
          have him prove it before you convert...hearing him say it isn't proof...
          • #35
            Hydrogen generator.... :bs:
            • #36
              Just remember that you cannot create more energy.... you can only unlock the potential energy that is contained in the fuel or chemicals that are already there. I think that the best method would be, as mentioned earlier, finding a way to utilize the waste heat that comes from burning the fuel. All this is doing, though, is improving the efficiency of the engine/system.
              How about this: using the exhaust stream to power a turbine that runs a generator to charge batteries or to provide power to an electric motor...kind of a hybrid concept. This way you are not creating generator-induced drag on the engine, and when the engine is under heavy load, the turbine and generator mechanism produces more power. It would be like a turbo... but without the fun. I wonder if the exhaust stream would have enough power to spin the turbine with a generator hooked up to it. Or if the blades would just stall or create too much backpressure to be feasible.
              • #37
                Might get something back, but I would think it would be more efficient to generate electricity by a mechanical coupling to the wheels or engine (like alternators already are). With a exhaust powered turbine, you would have losses in the form of backpressure slowing the exhaust and mechanical drag from spinning a turbine bearing at 20 kajillion rpms.
                • #38
                  Finally someone is listening to me.
                  This is a cool idea. Say if you cars powertrain is ran by electric motor you could technically have a 2 cyl running the turbo. Just have to have the technology in the ALT. Which we dont :(
                  Your car would really still run off of gas. More peddle, means more spool, means more enregy for the ALT. If we just had the alt, I could see this working.
                  I still think it would be better to harness the HEAT energy. Remember ALL, we only use about 25% of the energy we get from gas. Imagine if we used even 40% of that wasted energy :cool:
                  • #39
                    its not really converting it will be running on both hydrogen and gas at the same time all i would have to do is some wiring and mount it somewhere and run a hose into the intake
                    • #40
                      The turbine to generator link would have to incorporate some gearing to lower the RPMs and increase the torque. A good comparison would be a turboprop engine. However, this is what makes me wonder if the resistance to spinning the turbine would create too much backpressure.
                      • #41
                        Coat the pistons and cylinders with ceramic. Won't have as much heat transfer and ceramics can have less friction and better wear properties.
                        • #42
                          the combustion process would probably shatter the ceramic pretty fast, and if it didnt, i guarantee you detonation would
                          • #43
                            Well, okay, but it's already being done. Use of ceramics is becoming more common as a better understanding is achieved in the material science behind the adhesion of ceramic to metal. http://www.gizmag.com/go/5101/ (Sorry for the article being so old).
                            Other non-automotive companies have begun using ceramic coatings on frictional surfaces for it's superior wear characteristics over metal on metal. I seem to recall seeing a car commercial claiming specially coated pistons and cylinders, but I had no luck finding that online, so I won't claim that anyone is doing that now, but Ford is working on it. http://www.greencarcongress.com/2008...eveloping.html
                            • #44
                              thats kinda funny, is that a ceramic coating on the first article you posted?
                              those are sp pistons and i have seen their hyper pistons cracked and busted up all of the time.
                              i wouldnt use anything other than forged
