i currently own a 98 pontiac firebird 3.8 with no major mods, my o2 sensors are fine my oil filter is new my fuel filter is new, i have a lot of air flow (Ls1 intake) new IAT, i seafoamed the car, im out of options What else can it be?
Only getting 12.3 mpg!!!! Whats going on?
Re: Only getting 12.3 mpg!!!! Whats going on?
plugged cat, spark plugs, wires, coils, injectors, and more can cause fuel mileage issues. Also a lead foot
well thats why, you are doing it wrong
you need to fill it up all of the way 100% full, write down the mileage, drive around, fill the tank up again, see how many gallons you put in to make it full again, then divide that number by how many miles you drove
there is usually 2-3.5 gallons left in the tank when it reads E
and your tank is 15.5 gallons
yes, if you reset your trip od to "0" and then drive around like normal and then put gas in it again (when every that is....you don't have to be on empty).
fill up your tank.
take the miles you drove (per od) and divide by how many gallons you put in (per gas station tank).
example: 325.7 miles. filled up with 14.2 gallons.
325.7 miles/14.2 gallons=22.9 miles per gallon.
if ur getting 12mpg ur either doing ur math wrong or some thing uve put on is ****ing up. i beat the poop out of my car and never get less than 20 and 24 if im easy so u shouldent see under 15 ever.... and also if ur cat was plugged you would know it first off you'd have no power and theres a good chance you'd throw a misfire code
