Ok so my old pump was making noise and leaking every where so I replaced the pump yesterday well now I'm not getting any power assist at all. I did bleed the system and I did it just like my manuel said. Then I tried bleeding it again nothing .
no power steering after pump replacement
Re: no power steering after pump replacement
I know it sounds stupid , but did you fill it up and turn the wheels side to side holding it for a second each time. When you put the new pulley on did you press it on and no tuse a hammer(that can damage the shaft, thats why presssing it on is the best way). So it is not making any noise or sounds when turning or anything? Look at the pulley to see if it is slipping on the shaft for some reason. Other than that , its the only thing I can think of unless your rack and pinion is bad.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostI know it sounds stupid , but did you fill it up and turn the wheels side to side holding it for a second each time. When you put the new pulley on did you press it on and no tuse a hammer(that can damage the shaft, thats why presssing it on is the best way). So it is not making any noise or sounds when turning or anything? Look at the pulley to see if it is slipping on the shaft for some reason. Other than that , its the only thing I can think of unless your rack and pinion is bad.
