Ticking problem coming from drive shaft? - FirebirdV6.com/CamaroV6.com Message Board
  • Ticking problem coming from drive shaft?
    im having an issue right now where ther is a small ticking noise comeing from under the car from the drive shaft i have 98 firebird which came stock with a 2 piece drive shaft and broke so i replaced it with a Ls1 aluminum drive shaft and has been working fine till now it makes a small ticking noise when im rolling really slow im thinking its the seal on the trans to the shaft but im not sure has anyone expierenced this?
    Re: Ticking problem coming from drive shaft?
    You have a rear wheel bearing going out...hear the same ticking on mine when it's cold in the mornings.... $15-$30
      thats exactly what happens its only on cold mornings ! but how easy is it to change? and were can i get the part
        any parts store...
          awsome thanks alot for the advice and just one more questions if its ok? how do those usually go bad ? and why do they only make a noise in the cold?
            could be a u-joint
              lack of grease...would be my guess...
              do this test, jack the rear end up, and spin each wheel (grab at 12 and 6 o'clock)...if there is alot of play you have a bearing problem and if not then you have what tomham suggested a bad u-joint...
                im pretty sure its a bad u joint cause i just replaced it with the aluminum drive shaft that i purchased from a guy who had driven supposly 30,000 miles on it and after i installed it it has made that ticking noise.
                how much would a u- joint cost?
                and where would i get one?
