ok, my exhaust is rattling on a cross-brace right after the cat. i have bent it moved it braced it and everything to get the exhaust pipe off it. i was wondering if i just took that brace off for a short would that hurt anything? it aint holing anyhting up so i dont think it would
help with rattle...
honestly I had a slight problem with this too after I got my CAT replaced... I put a floor jack under the car, and jacked the exhaust up a little bit farther then I wanted(VERY SLOWLY), Even started to move the car a little. Then I let it down and never had a problem since.
..BUT, its a slim chance in my opinion, but figure I woudl warn you, you do put some stress and pressure on the exhasut manifold bolts, when you jack jsut the exhaust up. It is a possiblity you might snap one.
i took mine off and noticed no difference. maybe in 10 years when only 3 wheels touch the ground at once i will be singing a different tune, but it's working okay for now.
some people will say the engineers put it there for a reason and they did, but they also put little plastic caps on the lugs and rivet **** together so it will rattle and you will have no way to fix it.
my car is one giant rattle.. large babies play with me~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
