what the heck is going on.. exhaust rattle/shaking - FirebirdV6.com/CamaroV6.com Message Board
  • what the heck is going on.. exhaust rattle/shaking
    ok, so last night i went and got some gas, my car seemed 100% normal
    when i get back in my car and start it up, it is running really rough and shaking, and my exhaust sounded different
    at first i thought it could have been a misfire, because of the changed exhaust noise, but then i thought it might be the IAC acting up
    so i drive away, and my car seems fine, but louder
    so when im driving today, i notice that my car seems a lot louder than usual, idle was perfectly fine, just the car was louder
    i also noticed that my exhaust rattle has also somewhat disappeared, now this rattle REALLY sounded like it was coming from the front of the car, but maybe im wrong.. the rattle was there sometimes, but for the most part it seemed fine
    so what do you guys think this could be?
    -cat broke inside?
    -resonator went bad? (IIRC we do have resonators.. little square boxes on the exhaust somewhere??)
    -muffler broke?
    i just think it is weird that my car was running rough, then all of a sudden it gets louder out of nowhere, so im thinking something dealing with backpressure, which would make me think the cat
    Re: what the heck is going on.. exhaust rattle/shaking
    You sure your headers didn't fall off?
      How old is the cat in your car? You might be having some problems with the internals blocking it up. They have a tendency to rattle when they're going out. Also check to see if the welds on either side of it are still together. One of mine had broken and caused an awful rattle at lower rpms.
      From what I remember our cars don't have resonators. At least, I don't remember seeing one on my car's piping when installing the headers.
      '99 Camaro
      '04 Saab 9-3 Aero
      '90 Audi Coupe Quattro
        I would agree with pace, but if your rattling stopped and it's louder now, I don't think that would be it...I've gone through plenty of cats and well when the rattling stops is when the honeycomb has fully broken up and then shoved itself into your exhaust piping, which would cause the exhaust to sound lower, not higher...more wheezy, constricted than anything...
        check your header bolts...is your cat bolt on, check to make sure it didn't slide off....
          Check your heat sheilds. Look for random sheets of metal on the underbody, near the primaries and y-pipe, and make sure they're securely in place
            th cat is what im assuming is the stock one.. if its not stock, it was a factory replacement, and was welded back on.
            the car has 136,000 miles, and i have been battling this rattle for what seems like forever now.. over a year and probably 15,000 miles
            my rattle only happens when there is a load on the engine and when i press the clutch in to shift, it rattles when the rpms go down.. there seems to be a sweet spot, when i shift around 2500rpm it almost always rattles, but usually only going from 1st to second, and when i engine brake, it rattled a hell of alot
            last time i was under the car i checked the heat shields and they seemed fine, but i dont think that they are the problem since after my exhaust got louder all of a sudden it is rattling a lot less
            but yeah, the car just seems to be noisier now, doesnt seem to have lost any power or anything like that
            edit* oh yeah, it seems louder at the back of the car, like the muffler is bad, or like i just have a complete straight pipe in there.. its not obnoxiously loud, but loud enough for me to have noticed it
              Common, if the car's exhaust tone is different and there is/was a rattle. It's got to be the cat. And stock exhaust doesn't have a resonator. Possibly the ceramic or whatever is in the cat, after breaking down it can still get hot as hell and burn/bubble through the cat casing. Get under there and check it out.
              TEAM C6V6
                maybe one of your manifold/headers bolts came loose
                  yeah I came back to post this exact thing...if the pieces that broke up in the cat were small enough they could of made it past the prolly stock piping through your muffler and out your tailpipes...well it would basically make sense why it's louder and no rattle now...so yeah I think pace hit it right on the head...would of mentioned that...but with all your 3,000 posts I figured you'd know to check there first...so I didn't and i've never successfully blown honeycomb through my stock exhaust 'yet'. basically you have a straight pipe now...ha!
                    maybe it is the ls1's that have a resonator then.
                    it still could be that something in the muffler blew out
                    like i said it is louder at the back of the car at the muffler, it sounds like i put an aftermarket muffler on my car
                    i will get under the car and look at the cat
                      easiest way to check is to tap on it with either your hand or a rubber mallet, if you hear rattling your cat is dead. Then again you might of blown it all out and there will be no rattle... tap all around, don't just tap on the side...
                        oh, also I guess if it's blown out it may make a hollow sound (echoey)...that too will tell you if it's a bad cat or not...if your still not convinced, climb under someone elses car and tap on their cat and see if there is a difference in tones.
                          i found the problem
                          i have a factory dual exhaust that i bought off of a member here, from a v6 camaro, and the weld that the pipe goes into was shot and blew out
                          after i drove today my exhaust tips were like 3" from dragging against the ground haha
                          its weird because you would think that, that would be a problem that i would notice, not just all of a sudden happen when i start the car.. unless the shaking of the engine starting snapped the weld and it got loud.. still not sure if that would cause the engine to shake and run rough.. maybe because there was less back pressure?
                            Factory dual exhaust? You make no sense.. Make sense. I'd would normally assume you're talking about Dual tips.. But then you'd have to have the y87 package I believe but you haven't mentioned that. But you haven't mentioned anything about anything. So.. What happened with what?
                            TEAM C6V6
                              Originally posted by blizzard242 View Post
                              factory dual exhaust? You make no sense.. Make sense. I'd would normally assume you're talking about dual tips.. But then you'd have to have the y87 package i believe but you haven't mentioned that. But you haven't mentioned anything about anything. So.. What happened with what?
                              vvvvv
                              Originally posted by cam98aro View Post
                              i have a factory dual exhaust that i bought off of a member here, from a v6 camaro...
                              '99 Camaro
                              '04 Saab 9-3 Aero
