while i drive its at 60 but when I am stopped or at idle it drops to 30. Is this normal ?
oil pressure range
Re: oil pressure range
My 2000 Bird and 1999 Camaro never did this...
Why does my 1998? It has to be hot outside and sitting for awhile before it will drop, not near 30 though... Is it worn bearings; clearance maybe?
Jaysan, what year is your car?sigpic
Originally posted by nimrod.sixty9 View PostMy 2000 Bird and 1999 Camaro never did this...
i know the 98's had a different temp gauge than the 99+ so the oil psi gauge must be the same way
I know mine has to be real hot to drop below 60 PSI I use RP 20w50 , but it goes down to about 40-50 PSI , they make a oil PSI kit that will boost your oil PSI to around 80-85, this might be for turbos through, I don't know for sure.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Wow, so pretty much everyone has this then. Tonight Im going to look in the manuals to see what the operation rage should be...
So Im also guessing temp has to do with it as well. Hotter it gets the thinner it gets. Therefor going past the bearings quicker? And idle too, not enough RPM to build up enough pressure before it seeps through the bearings...sigpic
youre fine all the way up to high single digits. gm cars dont need much.
Follow me!
Or this
funny that you ask. mine sometimes bobs around (acts like it's got A.D.H.D). when I start her she goes to 60psi. As I drive it drops to 55psi anything above 1500rpm. when idle it drops to 25-35psi. and when i mean bobs it might show 25, then jump to 35 and back to 25, then 35 and so on. think i gotta drop the oil pan and check my oil pick up and if that's fine oh yay main bearings for me... *sigh* of course I'll check the sending unit first and a manual gauge before I do any of that...
Originally posted by ne0hisda0ne View Postfunny that you ask. mine sometimes bobs around (acts like it's got A.D.H.D). when I start her she goes to 60psi. As I drive it drops to 55psi anything above 1500rpm. when idle it drops to 25-35psi. and when i mean bobs it might show 25, then jump to 35 and back to 25, then 35 and so on. think i gotta drop the oil pan and check my oil pick up and if that's fine oh yay main bearings for me... *sigh* of course I'll check the sending unit first and a manual gauge before I do any of that...
Originally posted by ne0hisda0ne View Postwow, what auto part shop is open this late? 1 am? :burn::)Last edited by nimrod.sixty9; 05-23-2009, 04:01 PM.sigpic
