water wetter - FirebirdV6.com/CamaroV6.com Message Board
water wetter
  • water wetter
    Hey i used this stuff and it actually works any body else tried it. I heard it corodes the radiator but then again so does water.
    My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
    i've been using it, works nice, no problems so far
    New Car: 2004 GTP Comp G (Test Vehicle) 13.936@99.32 <br />Mods: Cylinder Filter,No Mufflers, 3.3\" <br />Old Car: 2000 Formula 13.124 @ 106.01 with 2.73\'s<br />Other Car: 1993 Firebird 16.1@83
      Yup yup [img]smile.gif[/img] same here dude, works like a charm. I'm running a few degrees cooler as well on average.
      Project: _*_*_*Knight Ryder*_*_*_<p>2000 Black chevy camaro<br />3.8L v6, AT, t-tops<br />borla adj. catback, gutted cat converter w/O2 sim, whisper intake lid, K&N filter, SLP ram air kit, 160 thermo, JET stage 2 chip, eibach pro kit springs, 1LE aluminum driveshaft, custom red and black interior<br />14.95 seconds at 90mph in the 1/4 <br />So much Rice...So little time :D:D:D<p><a href=\"http://www.geocities.com\\camarokidd10\" target=\"_blank\">www.geocities.com\\camarokidd10</a>
        Water wetter is designed for the track, where rules sometimes prohibit antifreeze (slippery if spilled). It provides corrosion protection and water pump lubrication that would be missing with plain water.
        Used in street cars with antifreeze, it's harmless but, IMHO, doesn't do much.
          I see alot about water wetter like in peoples sig. and stuff. But what does it actually do?
            My guess would be it breaks down the surface tension of water so the water can bond to the aluminum in the radiator.
            As a side bar, Rain-X works buy creating a molecule that bonds to the silicon oxide in glass on one side, and has a hydrohpobic (water hating) molecular chain on the oppsoing side. So when the rain comes, the hydrophobic portion wisks it away.
            [img]graemlins/burnout.gif[/img]
            Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
              i use water wetter and i also dump in a bottle of greased lightning for radiators. It has lube and protectant. Good ish. Keeps the pump moving freely and strong.
