So what could it be??? i thought it might be vac. leak but i havent found anything...what else could it be. at 1-3 gears, it rocks bad when u try to keep it at a lower rpm say 1800-2500, maybe more. any ideas on what to look for? and i havnet checked codes because of the 95 obd computer ****, so any ideas?
rocking bad at constant rpm speeds
Purple \'95 A4 RS...Totaled in \'03 23,000 on her :( Red \'95 Camaro M5...A Few Goddies!<br />84 Chevy 6.2L Diesel 4x4 10in. lift 38x15.50\'s<br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a><~MemberTags: None
The OBD1 computer is the easiest to check. Grab a paperclip and a code list, then get to work. ;)<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
mine is throwing a code, but thats not it. the OBD1 isnt what i have, its liek the 1.5 crap or something the way i was told. 95 was the year they changed. am i right 95 3.4 owners?Purple \'95 A4 RS...Totaled in \'03 23,000 on her :( Red \'95 Camaro M5...A Few Goddies!<br />84 Chevy 6.2L Diesel 4x4 10in. lift 38x15.50\'s<br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a><~Member
exactly... thats what i thought, tyPurple \'95 A4 RS...Totaled in \'03 23,000 on her :( Red \'95 Camaro M5...A Few Goddies!<br />84 Chevy 6.2L Diesel 4x4 10in. lift 38x15.50\'s<br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a><~Member
The OBD 1.5 (95-96) is simply a OBD1 ECU, with an OBD2 connector. You can fashion a adapter harness to pull the codes on 95 and a majority of 96 models, or simply ghetto rig something with jumper wires.
Do some research people! [img]tongue.gif[/img]<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
but like was said, its not getting any codes, im gonna put it on jacks this weekend and see what all i can come up with.Purple \'95 A4 RS...Totaled in \'03 23,000 on her :( Red \'95 Camaro M5...A Few Goddies!<br />84 Chevy 6.2L Diesel 4x4 10in. lift 38x15.50\'s<br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a><~Member
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
