Fuel Rail Cracked, upgrades? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Fuel Rail Cracked, upgrades?
    good to hear. ;)
    http://www.bowtiev6.com/
    • #17
      Originally posted by 97rs4life View Post
      good to hear. ;)
      You do know that now I'll expect you to keep me in check more often. Like this>:slap:
      TEAM C6V6
      • #18
        He is a great resource in a pinch. Got me hooked up with a throttle return spring when everybody was giving me that "what's that" look at parts houses and online.
        • #19
          I agree. He is one of the few that I trust pretty well when it comes to anything tech.
          TEAM C6V6
          • #20
            try ebay
            http://cgi.ebay.com/ebaymotors/95-99...spagenameZWD1V
            headers, high flow cat, slp loudmouth
            powerdyne supercharger 6psi
            GT2 cam. all done by myself :banana:
            Hell yea
            • #21
              Already bought and installed a replacement. 80 bucks. Apparently I had to buy injectors with it too? I now have 12 stock injectors. Ripped the rest of the schrader valve "stem" off the old rail when I tried to remove my pressure sending unit. Maybe I can find some other use for it... probably not. What kind of metal is that made out of anyways?
              TEAM C6V6
              • Andy H
                Transmission removal help!!
                by Andy H
              • 2.8 Bird
                Abs inop
                by 2.8 Bird
              • fishin
                by fishin
