You do know that now I'll expect you to keep me in check more often. Like this>:slap:
He is a great resource in a pinch. Got me hooked up with a throttle return spring when everybody was giving me that "what's that" look at parts houses and online.
Already bought and installed a replacement. 80 bucks. Apparently I had to buy injectors with it too? I now have 12 stock injectors. Ripped the rest of the schrader valve "stem" off the old rail when I tried to remove my pressure sending unit. Maybe I can find some other use for it... probably not. What kind of metal is that made out of anyways?
