Help...vaccuum line..thing.. blah - FirebirdV6.com/CamaroV6.com Message Board
  • Help...vaccuum line..thing.. blah
    Well I was tapping into a vaccuum line to hook up a boost gauge, ran into a problem...
    It's a little black cylinder behind the passenger side hood strut base, there is either 2 or 3 vacuum lines that go into it (2 I believe are Stable vacuum and 1 is actual intake vacuum from the TB). Basically just need to know what the part is called and partnumber/etc.. Cause the stupid brittle piece of plastic basically shattered as soon as I touched it. The car runs OKAY without it but I can hear the vaccuum leak from the actual line and I know the plastic piece had some sort of baffle inside it so I'd like to get it replaced and taken care of.
    Sorry, I know that's confusing...
    Sam
    :confused
    Sounds like a vacuum check valve. A dealer would have it...dunno about the parts stores though.
    Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
      I think I know what you are talking about.
      It is mounted w/ two bolts straight into the passenger side of the upper intake manifold.
      This is something that is a dealer or f body salvage yard only :(
      F body salvage would be cheaper
        <blockquote>quote:</font><hr>Originally posted by 12secondv6:
        <hr></blockquote>
        Its actually farther over, its next to the pcm... see the following image [img]smile.gif[/img]
        Its in the middle of the picture, has a white "top" and you can see the 3 vacuum lines coming off of it.. (not dialup friendly, 1meg picture)
        2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
          thanks for the pic...anyone else?
            <blockquote>quote:</font><hr>Originally posted by xjarayax:
            thanks for the pic...anyone else?<hr></blockquote>
            bump
