Help...vaccuum line..thing.. blah - FirebirdV6.com/CamaroV6.com Message Board
  • Help...vaccuum line..thing.. blah
    Well I was tapping into a vaccuum line to hook up a boost gauge, ran into a problem...
    It's a little black cylinder behind the passenger side hood strut base, there is either 2 or 3 vacuum lines that go into it (2 I believe are Stable vacuum and 1 is actual intake vacuum from the TB). Basically just need to know what the part is called and partnumber/etc.. Cause the stupid brittle piece of plastic basically shattered as soon as I touched it. The car runs OKAY without it but I can hear the vaccuum leak from the actual line and I know the plastic piece had some sort of baffle inside it so I'd like to get it replaced and taken care of.
    Sorry, I know that's confusing...
    Sam
    :confused
    AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
    Sounds like a vacuum check valve. A dealer would have it...dunno about the parts stores though.
    Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
      I think I know what you are talking about.
      It is mounted w/ two bolts straight into the passenger side of the upper intake manifold.
      This is something that is a dealer or f body salvage yard only :(
      F body salvage would be cheaper
        <blockquote>quote:</font><hr>Originally posted by 12secondv6:
        <hr></blockquote>
        Its actually farther over, its next to the pcm... see the following image [img]smile.gif[/img]
        Its in the middle of the picture, has a white "top" and you can see the 3 vacuum lines coming off of it.. (not dialup friendly, 1meg picture)
        2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
          thanks for the pic...anyone else?
            <blockquote>quote:</font><hr>Originally posted by xjarayax:
            thanks for the pic...anyone else?<hr></blockquote>
            bump
              Had to be evacuated again due to fire
            • RPDRed6
              For Sale: 2001 Chevrolet Camaro project.
              by RPDRed6
              Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
              No start problem
