i have a 98 firebird with about 102000 miles i just noticed the other day that the oil pressure gauge was acting funny cause at normal driving the needle is 3 qaurters of the wqay up whats going on
Oil pressure gauge acting funny ???
Re: Oil pressure gauge acting funny ???
he has electric.
that should be right...about 55-65 psi oil pressure.Team NoVa
im a bit confused, but if he has an aftermarket gauge, and it is messing up, i would check the grounds and the connections going to the gauge
i have an autometer tach w/ shift light in my other camaro, and sometimes the rpm's will freak out and jump around a bit, and its due to bad wiring somewhere (or a bad coil)
Originally posted by robert View Posti have a 98 firebird with about 102000 miles i just noticed the other day that the oil pressure gauge was acting funny cause at normal driving the needle is 3 qaurters of the wqay up whats going on08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostThats not bad 3/4's thats really good, when it is at 1/4 you should be worried. Pretty soon I plan on putting a PSI kit that ups my oil PSI to 80-85PSI for the turbo. So thats about 3/4's.
its a little low, but i dont know how accurate the gauge is
when i change my oil, it reads around 60psi at 2krpm until about 1000 miles
Originally posted by cam98aro View Postmy oil psi gauge says 30 at idle (when warm) and around 55 at 2krpm
Originally posted by ne0hisda0ne View Post^ yep mine does the same...actually mine is dipping slightly lower than 30psi now...and barely see's 60psi...08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
im thinking of doing to kit on intense too, lemme know how it goes.Team NoVa
Originally posted by flamingchicken View Postim thinking of doing to kit on intense too, lemme know how it goes.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
well, if i cant get the lifters from dude, then ima have to buy them new, then i wont be able to buy your stuff...its all resting on getting the lifters for cheap...Team NoVa
