i recently had the post bout having trouble with the ignition and the shifter.the problem was at the break pedal. when i hit the break to unlock the shifter from park id wouldnt unlock. theres some kinf of releas or sensor at the break pedal that was loose,then tightened. and presto all systems functioning. question: what exactly is the cause and the name of the locking system. ive got a repair manual ans i could not find it at all.tanx 4 all and any info guys.peace
