I did a search but didn't find anything. Anybody know where I can find performance aftermarket pulleys for a 99 3.8 bird?
3.8 Pulleys??
try zzperformance.com . i think they have some there.<b>2000 Firebird </b><br /><i>old setup </i>- Automatic Whisper lid, Borla catback, shift kit w/ V8 servo, 3.42 gears w/ LSD, PI 3000 converter, <br /><br /><i>14.703@90.92, 2.01 60\' </i>(intake and exhaust)<br /><br /><i> new setup </i> swapped over to LS1 413.9rwhp/398.7rwtq<br /><a href=\"http://www.thunderracing.com\" target=\"_blank\">www.thunderracing.com</a>
Also, I heard that it will only give about 1-2hp increase for the underdrive pulleys. I don't know about y'all, but I would like to get a heck of alot more hp for tearing the old pulleys off and replacing them. 1-2 doesn't thrill me, 10-50 does.
Just my opinion.
-Marcsigpic
Moving to general tech.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
the 1-2 is an old rumor... You'll actually get ~5-7rwhp max with both the underdrive and the alternator. This has been confirmed on ClubGP, and yes its a worthwhile mod. I want both but I am waiting until I swap my belt to do it.2002 5-spd NBM Camaro
Details: www.1lev6.com
I bought the waterpump pulley from ZZP. I don't know if we have more space between our pulleys than the 60 degree 3800 the GPGT uses, but it sure looks like you can manage the alternator pulley also without going to a new belt. I couldn't use the instructions they gave me to put the belt back on, I had to bypass an idler pulley temporarily, and then muscle it back into place, so there must be some differences. Can't assure you on that though. Can't tell you of any gains, I did to many mods at the same time.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
I could not fit a new belt with a w/p and a 20% altenator pully, but I replaced the belt with a shorter one and by passed the A/C. The belt rubs a bit leading to the altenator but the clearance will wear in.97 RS, M5 Y87 (3.42rear, posi, a/c)<br />35mm/25mm solid swaybars, BMR moly STB, alum DS, adjustable panhard bar, GM ZR1 17X9.5 w/275/40 BFG KD\'s, 360lb front & 140/170 rear springs, Koni SA shocks, poly bushings all round. CAI K&H filter, 160 thermostat, Edelbrock cat back, rollbar, pair red competition seat & belts,red carpet & door pannels, redline lubricants all round.
<blockquote>quote:</font><hr>Originally posted by prdcp97v6:
I could not fit a new belt with a w/p and a 20% altenator pully, but I replaced the belt with a shorter one and by passed the A/C. The belt rubs a bit leading to the altenator but the clearance will wear in.<hr></blockquote>
Was swapping the WP pulley hard? How did you get the alternator pulley off?2002 5-spd NBM Camaro
i have a 98 a4 and i was wondering whats the difference between 5% overdriver and a 10% or 20% underdrive alternater pulley? hp, low-end and
top-end speed.My ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 hour ago
